CTRL key and bloc maiusc (Caps Lock) LED don't work
Hello everyone.
Recently i changed my macbook pro battery cause the old one was dead.
After installing the new battery everything looked normal except the macbook turning off at 40%. Problem solved using the combination to reset the SMC.
After awhile i started a game in cloud gaming where i use ctrl key to crouch and i noticed that my PG didn't crouch.
So i opened the keyboard visualizer and i noticed that every key works except for the left ctrl key. Also the green bloc maiusc (Caps Lock) LED stopped working, the key works fine but when bloc maiusc is active the LED still off. I already tried to clean under the ctrl key and i removed a lot of dirty thing but the key still not works.
How can I fix both ctrl key and bloc maiusc led?
Это хороший вопрос?
