Repair guides and information for the Nintendo Switch Joy-Con controllers.
170вопросов Показать все
My right joycon is not recognized horizontally
Hi,
Both of my right joycons cannot be used horizontally AND their sync light does not work. They do work fine when used vertically (either docked or wireless), but just cannot be used horizontally. Any idea what I could do?
Thank you!
Laurent
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
It could be that a connection is loose inside of the controller. The accelerometer might also have a short causing it to short when turned on it’s side. I hope that will help you. 🙃
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Thanks! I've ordered a screwdriver to try and clean the connection, and possibly check if anything got loose.
из
So when i open the controller and use some contact cleaner, it partially works, from time to time. But not when it's close. So some connection is loose. Both controllers that have this issue are right controllers and still charge. I'm trying to figure out what exactly couod be wrong.
из
Добавьте свой ответ
Laurent будет вечно благодарен.
Просмотр статистики:
За последние 24 час(ов): 2
За последние 7 дней: 13
За последние 30 дней: 40
За всё время: 873
