@reiseninaba you would at minimum need
1) fine tipped tweezers
2) hot air rework station (plus hot tweezers work great for this)
3) Amtech or Clone flux
4) Solder wire
I like to use AMTECH VS-213-A-TF Flux and 60% Tin, 40% Lead solder.
and then you need lots of practice. No matter how many YouTube videos you watch or guides you read Soldering Skills - iFixit none of it will be a substitute for practice. You do not want to practice on the board you want to fix. Get yourself a couple of scrap board with SMD components and practice on those. You have to comfortable and competent to accomplish this. A1286 820 2850 Kernel Panic Repair - YouTube and Macbook Pro 2010 kernel panic GPU issue repair: SOLVED! C9560 - YouTube
Yes, a magnifying source will be great for this as well but that does not necessarily require a microscope. ;-)
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
3
