Руководства по ремонту, разборке и поиску неисправностей для Apple iPad 7-го поколения с Wi-Fi, доступного с накопителем на 32 или 128 ГБ. Выпущен в сентябре 2019 года. Идентифицируется по номеру модели A2197.
Does anyone know for sure if the ipad 7,8 and 9 Use the same port?
Does anyone know for sure if the ipad 7,8 and 9 Use the same charging port? I did a 9th Gen port replacement the other day and realized that it was labeled 7th Gen when I was finished. It did work fine but any time I search online they are sold individually for each model rather then listing compatibility for all 3. Just curious if anyone has any insight on this.
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
hello rich,
yes you are right. The ports for the ipad 7, 8 and 9 models are the same devices :-) Same as home button connector flex, earphone jack flex, even batterys :-) are the same. Digitizer is the same, and (of course) LCD matrix.
but for seriously, the ipad is a budget device. The differences between models 7, 8, and 9 consist in faster component parameters, which is associated with minor differences in the construction of the logic of the motherboard: for example, the processor power rim has an additional panel in the form of 68 logical pins. Of course, this is related to the different structure of the processor. All other parts (non-logical ones) remain identical. For reasons you can guess - economic.
whole true around the clock only on my blog :-)
Был ли этот ответ полезен?
Счет 1
This is no help to me
Счет 0
2 Комментариев:
I need to find a fixit store in my area any ideas
из Поделиться
@lorresommers There are no iFixit stores. Besides the one in California, you will not find any iFixit stores anywhere else. If you are looking for a repair store the iFixit has, you still won't find one. iFixit mainly supports self-repair. If you are having a problem with your iPad, go ahead and create a new question!
из Поделиться
Добавьте свой ответ
rich буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 65
За все время: 1,046
