The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
426вопросов Показать все
Do you need to use the exact same mosfet codes?
Im in the process of repairing and xbox one S, I've removed 2 shorted mosfets
Code - 4C50 RL33
However I cant seem to find these anywhere, the only ones I can seem to source are
Code 4C50 RK31
Would these be compatible?
There listed for xbox one S but other than these im rather stuck
I should add I'm based in the uk
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
From my research, the 4C50 RK31 chips should work. I believe the first line is the component code and the second line is a lot number or something similar.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Ronnie Roberts будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 83
