The Meta Quest 2 (formerly Oculus Quest 2) was released in October 2020 and is the successor to the Oculus Quest.
164вопросов Показать все
Can you fix the part that charges a piece is broken in it .
Can you fix where my vr charges at a piece is broken in their I can’t charge it or play on it anymore can it get fix.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi Latrice,
The phrasing of your question seems to imply that you're asking iFixit if they can fix your Quest 2 VR glasses. If that's the case, I'm sorry to have to be the one to tell you that you're in the wrong place for that. iFixit does not do repairs; rather, they are a resource for people who want to know how to fix their own devices rather than send them out to someone else to do the repair.
So I'm guessing the following information most likely won't be of interest to you, but just in case I'm wrong, here's what you could do yourself to fix your glasses.
First of all, the good news is the USB port on your device isn't soldered onto the motherboard, so it can be replaced without having to do any soldering. It comes on a cable assembly that includes the headphone port, so you'll be replacing both of those items at the same time. Here are a couple of places you could buy those parts from; I usually suggest trying eBay, AliExpress and Amazon as well as a general internet search for your part.
Original Charging Port Flex Cable for Oculus Quest 2 Console Flex Charge Cable With Type C Charge Port for Meta Quest 2 VR
New Genuine Oculus Quest 2 Power & Aux Headphone Port Assembly Replacement Part
It's a little harder to locate specific instructions for that repair, but in general you should follow the directions in the teardown guide until you've removed the midframe. At that point you should have easy access to the headphone/charging port assembly and I'm betting it won't be too difficult to figure out how to remove it and pop the new one in.
Oculus Quest 2 Disassembly - iFixit Repair Guide
Sorry if this isn't what you're looking for, but there are repair sites offering that specific fix; the first one I came across is asking about $160 USD to do the repair if that's more to your liking.
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
Latrice Michelle будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 10
За последние 7 дней: 65
За последние 30 дней: 402
За всё время: 6,649
