Repair guides and support for Windows 7 OS, an operating system released by Microsoft in 2009.
7вопросов Показать все
How can we fix Operating system not found'
When i turn on i see he says operating system not found
Это хороший вопрос?
Оценка 0
1 Комментарий:
@jasmeetsin53641 let's start at the beginning. When you turn what on? What device are you referring to? I suppose it is a computer. What have you checked? Did this happen all of a sudden or were you working on something? The more history and background that you provide, the greater your chance of getting a good answer.
из
Добавить комментарий
1 ответ
Well you can try the following.
  1. Check the BIOS. You need to check for two things in the BIOS.
  2. Reset the BIOS.
  3. Fix the Boot Records.
  4. Enable or Disable UEFI Secure Boot.
  5. Activate the Windows Partition.
  6. Use Easy Recovery Essentials.
  7. Reinstall Windows.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Jasmeet singh будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 46
