Cardo Systems motorcycle bluetooth headsets: Packtalk, Smartpack, Packtalk Bold and Packtalk Black
Replacement USB connector P/N on PCB?
As with many other users I have a Packtalk Bold out of warranty with a bad USB connector. It works if the cable is held pressed up or down. Many have had solder failures but not this one, I need a new connector but studying images and footprints at Mouser and DigiKey has failed to ID a likely candidate.
Это хороший вопрос?
Оценка 2
6 Комментариев
Did anybody ever find a solution to this problem
из
The YouTube link shows someone doing it, not someone willing to share the P/N.
из
Meh. My question is, “what is the part number of the usb socket?” The YouTube video and poster refuses to share his secret.
из
Показать 1 больше комментариев
Добавить комментарий
Ответов (3)
Выбранное решение
you can find the correct USB connector here....warning...its a bit tricky without the right equipment. I have successfully fixed two so far with USB replacements. If the trace has pulled away from the board....you may need to fix that also. https://www.amazon.com/gp/product/B00NQB...
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thank you I bought a couple of these off Amazon from your link from uxcell and had my local “iKrack” micro solder shop replace one for me. It worked well.
из
Наиболее полезный ответ
is standard micro usb, but many Times on this model is the PCB lines missing, then need make jumper.
Оценка 2
There is a good Youtube video on this process: https://www.youtube.com/watch?v=FLr-Keiv...
Оценка 0
Добавьте свой ответ
David kelly будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 5
За последние 7 дней: 21
За последние 30 дней: 86
За всё время: 1,058
