Voice memo and phone noise
hello my name is Mike,
I am from Germany.
my English is not the best.
But I hope you can help me anyway.
I have an Iphone 3G-S with IOS 5.0.1
It was never Jailbeaked.
When I record a voice memo with the Iphone then rushes the microphone.
The same is also on the phone.
Also the use of the headset does not bring improvement.
I reset the iPhone to factory settings, but without success.
I've replaced the dock connector, but without success.
I replaced the headphone jack with flex cables, but without success.
When I play music, there is no rush.
Only when I play recorded voice notes or phone calls.
Did you have a solution? I'm getting perplexed.
Это хороший вопрос?
1 Комментарий
your English is better than mine! I'll have a search and see what google throws out but it may be the noise reduction "inductor"?? near the no4 connector. It's a tiny little part about 1mm long. I think this sounds like a problem that a user called James Bond solved and put a good answer to. Maybe you bumped it off in a previous opening?
из pollytintop
