HP Laserjet Pro MFP M476nw starting loop
Hello
I'm owner of a HP Laserjet Pro MFP M476nw.
Today I switched the printer on.
The bar on the display started as usually but suddenly after 1/3 of the length the printer switched itself off and on and keeps on looping.
I already reseted all the configuration but no success.
The printer keeps looping at the start sequence.
I didn't find any hint on the net.
Cann someone help?
Regards,
Marcos
Это хороший вопрос?
9 Комментариев
@marcos4301 Does the printer have an external power brick or is the power supply in the printer?
из Andrew S
@andrewsawesome The power supply is in the printer.
из Marcos
@marcos4301 Do you have a multimeter?
из Andrew S
@andrewsawesome Yes I have.
из Marcos
@marcos4301 I don't know if you're going to be able to do this with your printer's setup, but if you can, check the voltage output with a multimeter. Does the voltage drop to 0V when the boot loop starts again?
из Andrew S
Показать 4 больше комментариев
