Released in June of 2011, ChromeOS is the proprietary Linux-based operating system developed by Google.
2вопросов Показать все
How can I stay logged onto my Chromebook?
Every time I turn my Chromebook off I have to login to my device. Can I log into my Chromebook one time and stay logged on permanently?
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hey Mike,
Your Chromebook does this to keep your Google Account safe, and prevents others from accessing or changing your account. Although if you still wish to keep this from happening then you can go into Settings then Screen lock and Sign-in. From there just turn off "Show lock screen when waking from sleep".
Again, I recommend that you don't disable this feature as it is a security feature, but this is the process you would want to use if you still want to do this.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
+1 to that. I have also seen it is possible to add a PIN on that same menu as a sign in method on some Chromebooks so you don’t have to type the entire password in every time.
I don’t believe you can keep it from asking you if you restart, or power off your device, only when it is waking from sleep, but I don’t suspect most people power down their Chromebooks often anyway.
из
Добавьте свой ответ
Mike mike будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 16
За последние 7 дней: 179
За последние 30 дней: 682
За всё время: 1,383
