Samsung's tenth flagship Galaxy phone, released in March of 2019. Shipped with Android 9.0 (Pie).
69вопросов Показать все
Speakers do not work on my S10
Hello,
My Speakers do not work on my S10 after I changed the camera.
Tried to change the bottom speaker, but it does not work.
Ordered a TOP Speaker now to test it.
Is it possible that the bottom speaker does not work if the TOP speaker is faulty?
Might the little crack in the Wifi Antenna thingy has anything to do with the speakers not working?
Best regards,
Luca
Это хороший вопрос?
Оценка 0
4 Комментариев
did you tear any cables? you should take a photo of the wifi antenna and post it please :) Adding images to an existing question
из
There are no cables going to the speakers.
Later I will send a picture.
из
Hi Barula,
Which camera did you replace? The replacement procedures for the front and rear cameras are very different.
из
I replaced the rear cameras, because the older one had a broken lens.
Camera is working fine without issues.
Problem is, whenever i test the speakers in the "*#0#* menu, they both dont work.
Normally the speaker on the bottom should make a sound if the upper speaker is defective or am I wrong?
Best regards
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi Barula,
Okay, I'll try to address all the items being discussed.
First of all, it doesn't look like there is any reason why the broken WiFi Antenna panel should affect the speakers, so I wouldn't worry about that. If you have issues with wireless charging or WiFi connections, then you might need to consider replacing it, but for the purposes of getting the speakers working again that's not a concern.
Next, while it's always possible Samsung did something weird with the speakers, most likely there should be no reason why the lower speaker would not work just because the top speaker isn't. They use completely different connectors and speakers, but they almost certainly have an audio IC in common on the motherboard. That's the only reason I can think of as to why both audio channels would fail at the same time. If that's the case, it would require board-level repairs that are generally out of range of the skill set of even the most experienced of us home DIY-ers.
But, there are a couple of things you can check. Both speakers rely on a pair of spring contacts to make the connection to the motherboard. Although it seems unlikely, it is possible you've got a bad connection on those contacts keeping your speakers from working. Here's where the contacts are on the front and rear speakers.
Lower speaker
Upper speaker
Make sure those contacts are clean; you might go over them with a pencil eraser to make sure.
Here are the pins on the motherboard that those contacts have to touch.
Lower speaker
Upper speaker
Again, you'll have to check those spring contacts. Clean them with isopropyl alcohol and make sure they aren't flattened to the board, that they have some spring in them. You may have to carefully bend them up a little from the board to make sure they're going to make contact when they're placed next to the speaker they connect to.
You could try doing a factory restore of the phone to eliminate the possibility that this is a software problem; that might be worth trying first before you open the phone back up and start tearing it apart again.
Other than that, I'm out of ideas. Hope something in here helps; let us know what you find.
Update (05/10/23)
Yes, you are definitely missing a component there. Without seeing a set of schematics I can't say for sure whether that part has anything to do with the audio channels, but it is entirely possible.
The S10 iFixit used in their teardown has a different motherboard than yours, so that wasn't helpful in figuring out if you're missing something, but there's a French site called SOSav that has a motherboard guide using the same one you have. Here's a picture of the component you're missing.
I'll keep looking, but at the moment I can't tell you what that part is.
Update (05/10/23)
Alright, found a few diagrams, but not yet able to determine exactly what the part is. Here's where I found the board information.
SAMSUNG GALAXY S10 SM-G973F
From the board layout file, the part we're looking for is labelled TA8004. It's labelled in red.
There are two other instances of the same part used on the board; they're marked in orange; parts numbered TA8003 and TA8005. Here's the component list for those parts.
The only thing I can gather from that sheet is that it's most likely a Tantalum capacitor, and that the three parts listed together are the same. Unfortunately it doesn't seem to give any more information about the specifications for those parts.
Update (05/10/23)
Probably not that much help, but here's the official Samsung troubleshooting chart for the speaker.
Был ли этот ответ полезен?
Оценка 3
9 Комментариев:
Hello,
Thank you for the detailed answer, but did all of that.
You mentioned the Audio Chip and I tried to find it on the motherboard by looking at teardown pictures in google and it seems lile there is missing something.
Might that be the cause for the faulty Audio Chip?
из
Uploading the picture on my first post.
из
Ye, I can't find it either.
Are you 100% sure that there is missing a part?
I have seen 1-2 on Ebay, where the component is also missing.
из
The chip right next to the possible missing part is called "Cirrus Logic CS35L40 Audio Amplifier", so that is why I was hoping that this might be the problem.
Anything audio relevant on the phone is not working probably.
Whenever I try to put the volume up, it just bugs and the volume just jumps around.
из
Ye, found that too just now.
Probably gotta buy a faulty mainboard and take the part from there.
Thank you for the help though! :)
из
Показать 4 больше комментариев
Добавьте свой ответ
Barula Cyki будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 19
За всё время: 162
