OWC Aura Pro X2 SSD won't fit
Trying to replace the SSD with the Aura iFixit recommends but it doesn't go down far enough to replace the screw.
Update (05/11/23)
Это хороший вопрос?
Это хороший вопрос?
Can you post some pics so we can see things. Show us the screw location with the drive in place. A second looking down into the socket.
Был ли этот ответ полезен?
updated with photos
@lumivuohi - I can’t tell for sure as I can’t see deeply enough T into the slot to see if you have a bent pin blocking things.
Assuming it’s not then you need to apply a tad more pressure sliding the SSD into the slot. Make sure you don’t lift it up as that could damage things.
Hint! There is a key way in the connector the gap you see now needs to almost be gone when fully inserted.
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 46
