The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
268вопросов Показать все
What charging assembly would I buy?
i have a Samsung galaxy with a heavily damaged charging port, and here on ifixit there is only Verizon and AT&T charging assemblies...only issue is the note5 i have is locked to sprint.... would i be able to use a at&t charging assembly...?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
I can't answer as to whether an AT&T port would be usable, but I do see where other sites are selling the ports specific to the carrier. In your case the model number of your Note 5 would be SM-N920P, and searching for a charging port using that number returns several specific results that are for that Note 5 and not others.
NEW OEM Charging Port Mic Flex For Samsung Galaxy Note 5 N920 All Models
Samsung :: Note Repair Parts :: Samsung Note 5 Parts :: Samsung Galaxy Note 5 Charger Dock Connector Flex Cable - Sprint(920P)
Amazon.com: ePartSolution Replacement for Samsung Galaxy Note 5 SM-N920 USB Charger Charging Port Micro Dock Connector USB Port Flex Cable USA (N920P (Sprint)) : Cell Phones & Accessories
My suspicion is the ports are particular to the carrier for some reason, so I'd suggest sticking with the original carrier.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
timtom7777 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 24
