Руководства по ремонту, разборке и поиску неисправностей для Apple iPad 7-го поколения с Wi-Fi, доступного с накопителем на 32 или 128 ГБ. Выпущен в сентябре 2019 года. Идентифицируется по номеру модели A2197.
ipad 7 no life, charging at 0.08 amps
I bought a broken iPad 7 off the Facebook marketplace. I thought it would be a fun and educational project.
It has shown no signs of life. Replaced the battery, and still has no signs of life. I purchased a USB voltage monitor and tested the charging. It is getting 0.08amp of power draw when plugged into a known good charger. Is this a charging port issue or a possible mainboard issue? or something else?
What are some tests I can perform to diagnose this?
Thanks
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
download a program called 3utool on a pc/laptop, connect the ipad to the computer after installing that check if the ipad is in dfu mode. if it is you can use the program to try exiting dfu but if it goes back to dfu mode or even shows connect to itunes etc it could be a board issue as ipad 7 has a problem with the cpu disconnecting and needs reballed
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Cooper Goswick буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 13
За последние 30 дней: 39
За все время: 577
