The Samsung Galaxy A20 is a complete Android smartphone. It has a 6.4 inches touchscreen display. Display resolution 1520x720 pixel. It has an LTE 4G module that allows a fast data transfer and an excellent internet connection, with Wi-Fi and GPS as well.
7вопросов Показать все
How do you fix the screen if it's showing grey on the whole screen
My phone has been showing grey on the screen recently and it always goes back to normal but last night I seen it was grey and just waited like I always do but now I'm not sure pls help
Это хороший вопрос?
Оценка 0
2 Комментариев
It's display gonn it showing colorfull straight lines
из
im not abel to turn of the grey.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
How to Fix a Grey Screen:
  1. Force Restart: Start by performing a force restart on your Samsung phone. Press and hold the power button and volume down button simultaneously for about 10-15 seconds until the device restarts. This can help resolve temporary software glitches.
  2. Clear Cache Partition: Access the recovery mode on your Samsung phone by powering it off and then holding the power button, volume up button, and home button simultaneously until the recovery menu appears. Select "Wipe Cache Partition" using the volume keys and confirm with the power button. Reboot your phone and check if the grey screen issue persists.
  3. Check Display Settings: Ensure that the screen color mode is not set to grayscale. Navigate to Settings > Display > Screen mode and select a suitable color mode such as Adaptive Display or AMOLED Cinema.
  4. Safe Mode: Boot your phone in safe mode to determine if any third-party apps are causing the problem. Press and hold the power button, then tap and hold the "Power off" option until the "Safe mode" prompt appears. Confirm and observe if the grey screen issue persists in safe mode. If not, uninstall recently installed apps that may be causing conflicts.
  5. Professional Repair: If the above methods fail to fix the grey screen issue, it is advisable to consult a professional technician or visit an authorized service center. They can diagnose and repair any underlying hardware problems effectively.
more info
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Jojo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 19
За последние 7 дней: 69
За последние 30 дней: 289
За всё время: 1,324
