Why,no sound on calls but speaker works?
Changed Battery, all works exept the no sound on calls but if i press Speaker it is Ok,Sound on other apps Ok.
Это хороший вопрос?
Это хороший вопрос?
you need to check connector no.3 is in properly, it can be a little tricky. push the flex in until you meet resistance, not up to the white line it will be about 1mm from the connection, then push the lock down.
Был ли этот ответ полезен?
Hi Pollytinto,i didn`t realise that it slid into the connector(3) thank you so much. It is very difficult to connect and should be the first when replacing Screen assy. Thankyou Ted.S
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,829
