Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
139вопросов Показать все
How do I unlock my hard drive locked by bitlocker?
Hi, I had my Hp probook 430 G2 laptop which crashed few days ago and the last time I was using it was locked by bitlocker, following crash I decided to take out the hard drive from the laptop and connecting to external hard drive case so that I can recover my documents to my office computer,
Unfortunately it rejects the bitlocker password that I used the past days when it was in my laptop, I don't know what to do next.
Please!
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
If the password that you used is not valid when booting it as a secondary disk, you may need to find your recovery key.
This is different than a password. It is a randomized string of 48 characters organized as such:
A1B2C3-D4E5F6-G7H8I9-J0K1L2-M3N4O5-P6Q7R8-S9T0U1-V2W3X4
If you do not have your recovery key documented anywhere, you can find it by logging into the Microsoft account associated with that recovery key, verifying your identity, and then recovering it there. See those steps here: https://support.microsoft.com/en-us/wind...
Depending on a number of factors, you may or may not be able to unlock this drive when using it as an external drive. If you are never able to access the "insert your recovery key" screen, you may need to use it as a boot drive. Your computer will have an option during bootup, typically something like pressing Esc, F2, F8, F12, Del, etc. Mash that button during boot up and you'll be taken to your BIOS screen, where you can change your boot priority to favor the external. So long as that drive was not the cause of your old computer crashing, you should be able to boot from it even as an external drive, letting you get in and remove the bitlocker encryption so that you can safely remove all of your data.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Shanel Vitus будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 20
