PC crashes/freezes whenever I plug something in an usb port
So recently after i installed an Corsair watercooling to my custom pc it sometimes crashes when i connect something to an usb port. Any ideas?
Это хороший вопрос?
Оценка 0
9 Комментариев:
Have you tried different USBs/ports?
из
Unfortunatelly it is not something i can easilly test out because does not happen often. i'll try some ports and then report back.
из
No problem!👍
из
When it crashes, does it blue screen?
из
@thomasdeboer
What is the wattage of the PSU?
Is it sufficient to handle all the power requirements for the motherboard, board powered peripherals etc as well as now the extra water cooling feature e.g. pump if powered internally?
из
Показать 4 больше комментариев
Добавить комментарий
