The current line of iPod touch comprises seven (7) different generations.
2615вопросов Показать все
Ear phone jack operates intermittantly.
Ear phone jack operates intermittantly. Seems to have a bad connection with only one side playing till you jiggle the wire.
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Definitely needs a new headphone jack. This is possible to replace yourself, but it is tricky. I don't think iFixit carries this part, but I know you can get the part from eBay for about $5-$10. What generation of iPod Touch do you have? For the first gen iPod Touch, you just take off the backplate and unscrew a couple screws around the headphone jack before unsoldering the 4 points that hold it on. Carefully remove the old and stick the new one in, and resolder. The 2nd/3rd gen iPod touches are a little different (you have to take them apart a bit more) but can still be done.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Also, you can buy the headphone jack for 1st gen touch at iTronics Repair.
из
Добавьте свой ответ
Gary будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 798
