The Galaxy A12 is a low-end slate Android smartphone released by Samsung in November 2020 as a successor to the Samsung Galaxy A11. Identifiable by model number SM-A125 (followed by version/carrier-specific character.
160вопросов Показать все
Why the not detecte earphone
My phone is not detecting earphone when i plug in
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
@michael45594 could be a bad headphone jack or a bad board. I would go ahead and replace the Sub board (charging board) which holds the headphone jack. Use something like this guide Samsung Galaxy A12 Disassembly to change it. Step 6 shows you the removal.
When you order a replacement, make sure that you get a charging board that it appropriate for your Version of the A12.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I ran across a video showing the charging board replacement (which also contains the earphone jack) that you might find useful.
https://www.youtube.com/watch?v=TVJN4FYk...
из
Добавьте свой ответ
Michael будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 29
