Fans louder after thermal paste job, despite a lower temp.
I just replaced the thermal compound of my old MacBook Pro (high quality grease, the old one was dry as dirt).
Before that, I had to underclock it from 2 to 1GHz to keep it stable (using Coolbook). The temperature at rest was around 55°C, and at full CPU load, it would reach 72 °C. The fan never kicked in at that temperature (never loud, but I didn't measure the speed at that point), but if it stayed that high for too long, the machine would freeze.
After the paste job, at 1GHz, even under load , the CPU temperatures (Core1, Core2 and CPU temperature diode) don't exceed 53°C. However, in these conditions, the fan runs at 3800 RPM (louder than what I remember it was before).
If I increase the clock speed, the fans accelerate, and reach 6000 RPM under load at 1.5 GHz. The temperature is then around 65-70°C
I measure the temperatures using Marcel Bresink's Temperature Monitor and the fan speeds with Lobotomo Fan Control. The latter is supposed to enable tweaking the fan speed settings, but it doesn't work here.
I also noticed that the temperature is now more volatile than it used to be.
Thanks in advance for your help.
Это хороший вопрос?
Оценка 2
Добавить комментарий
Ответов (3)
Выбранное решение
Well yes, if the fan's never kicked in, or ran only at low speed, now that they run at 6K RPM they'd seem noisier. They'll also burn out faster. Maybe you'll want to order replacement fans so they'll be ready. Breakdowns always seem to happen late at night on Sunday a Monday morning deadline.
If this answer was helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
Thanks for the tip, but I'd rather have them run slower...
Any idea of what could cause the behavior?
из
Наиболее полезный ответ
Fans do not decide to run fast on their own and replacing the fans will not solve the the underlying problem or make the fans run quieter . The SMC tells them how fast to run, (under normal circumstances) based on what some temperature sensor(s) is telling it. If the SMC can't find some hardware it needs to communicate with it will put the fans on high to prevent damage and let the user know something needs attention. Your temperatures don't sound bad at all. I suggest starting off by resetting the SMC and PRAM to see if that tames the fan speeds down. Click here and click here for instructions on how to do the resets. If that doesn't resolve the problem download iStat by clicking here, a free program/widget, to monitor your temperatures. That program monitors more than the temperature under the CPU. Please post the temperatures (with and without the system under load) it gives here.
Next I suggest you run AHT (Apple Hardware Tests) to see if you are having sensor problems. If your laptop still has the original hard drive and it hasn't been repartitioned you can boot while holding the D down and access it. If that doesn't work the AHT is on the original disk(s) that came with your laptop. If AHT gives any error codes please post them here.
I read you had temperature problems prior to changing the thermal compound, but the fans were running at a "normal" speed. I'd double check all that the heatsink is properly seated, also that all the wires/cables are seated correctly and in their proper place. You did not mention what thermal compound you used, I suggest Arctic Silver 5. Thermal paste needs to be spread out on the chip very then and evenly. Too much can cause problems.
If everything checks out good with AHT, the connections are in order and resetting the SMC did not resolve the issue. I would replace the heatsink along with the sensors on it. If the heat tube on it has been compromised heat won't be drawn away from the chips as it should and the SMC will see the imbalance of temperatures between the chips and the heatsink, then raise the fan speed to prevent damage.
Оценка 6
3 Комментариев:
Thanks for your answer, this is exactly the response I was looking for.
I know that the fans are not endowed with free will, I just didn't know what commanded them... Now I know!
For the thermal grease, I used some spare Cooler Master Thermal Compound (It has good ratings). I spread it evenly and as thinly as possible. Some of it spilled after I put the logic board back in place, so I guess that I could have put less...
Regarding the cables, I lost a small brown plastic piece that was holding the cable of the left ambient light sensor [1]. Is there a thermal sensor attached to that small board?
Anyway, I'll start with the software tests and report back. I'm clumsy, so I prefer to avoid manipulating the innards of the machine for no good reason.
[1] MacBook Pro 15" Core Duo Model A1150 Left Ambient Light Sensor Replacement
из
Did you reattach the ambient light sensor cable? If so, how did you do it? That very well could be the cause of the fans running as they are. The SMC will kick up fan speed if it does not detect something it should or there has been a major reconfiguration of the system. The SMC reset I suggested in my answer may resolve the fan issue. iSatat and the program you mentioned will tell us if the temperatures are wacked out.............. I figured you understood that the fans don't have free will.....There may be some that don't ;)
из
Sounds like you gave a good easy to understand answer! Kudos to you. See, I am not using an Apple or Mac. I have Dell Dimensions but have had this similar problem but a different problem. I have 3-4 P.C. s' sitting around and disabled from work now I am trying to get them up and pass them on or sell. I was cleaning the Dell and removed the cowl over processor and it took cpu out with it to my surprise. I cleaned cpu well put thermal Arctic silver on. PC would not boot but did give beep and number errors. Well at this point I put it in the corner where it sat for about a year. Last night I cranked it up and the darn thing booted right up! After about 5 min. the hard drive was wound out to full rpms???, I since have read about replacing cpu's and I did a sloppy job I see now. But, would the bad placement of thermal comp. cause Hard drive to wind out like that. It is possible it's the fan? I also found a connector stamped p-12. I guess it is an extra open connector.
из
And I agree, processor cooling fans don’t have a mind of their own and just shift into overdive on freeway. May be a good learning experience for you, I know the paste does need some care applying, A card comes in handy to spread it evenly. And it is not a case of “a lot is better” a thin even layer should work well. I admit I had a time with mine but after it did run correctly after sitting for some time , I took processor off cleaned with 91% alcohol and a nice thin layer of Arctic Silver, I hope you found your answer above as it sounded right on the money to me. One thing about Computers is they can be a bit “cranky” at times but it is usually because a problem still lurks. Good computing and be safe. Chaosone7.
Оценка 0
Добавьте свой ответ
Ray Osgod будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 5
За последние 30 дней: 42
За всё время: 12,394
