Repair and disassembly information for Samsung's Galaxy A13 Android smartphone, released in March of 2022.
68вопросов Показать все
One UI 5.1 and battery life
Since the last update, my battery gets drained very quickly. I have all of the settings on to optimize. I close apps. I go on local wifi. Is there anything else I can do to make it last through my work day? It used to be 70 - 80% at end of day. Now it is 20 -30%.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Try shutting down all apps and putting on airplane mode to see if it still depletes fast.
If so, it is a battery/phone issue.
If not, turn off airplane mode and try again.
If so, shut down wifi and try again.
If not, open one app at a time to find the power hog.
You need to eliminate the possibilities.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I need to run it with 5G/wifi, so I can't leave it in airplane mode or with wifi off. Most times when I look in the battery usage the One UI is the largest hog. Most of my apps, I do not have set to run in the background.
из
Добавьте свой ответ
wrecky будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 38
