Repair and disassembly information for Samsung's S22 Ultra smartphone, released in February 2022.
53вопросов Показать все
replacement frame/screen is different
ordered replacement screen for s22 ultra, after tear down my phone ear piece speaker/vibration motor assembly is different than instructions and new frame. The piece from old phone will not fit replacement...even if i could order the new earpiece speaker assembly it appears the new pc wouldn't fit my old motherboard.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
@jebboon did you check the version on the back of your phone to ensure you ordered the right replacement. Let us know what exact version your phone is and maybe consider posting some pictures of the replacement part you got. It sounds like you have either ordered or received a wrong part. Adding images to an existing question
Contact the vendor (you did not tell us where you purchased it from) and discuss a replacement.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
In practice, it shouldn't matter anymore since the U/U1 shift since the difference is the carrier lock status basically with the same phone, the bloat can be removed with the Samsung unlocked ROM private key now. But maybe some parts have differences still.
из
Добавьте свой ответ
jeb Boon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 7
За последние 30 дней: 32
За всё время: 179
