Kodak PixPro AZ251 is a 16 Megapixel digital camera from Kodak released in 2013. It has a optical zoom of 25x and Optical Image Stabilization (OIS).
8вопросов Показать все
Why did my cameras screen turn off but the lens didn’t go back in?
why did my cameras screen turn off but the lens didn’t go in?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
@snjsjs it may have turned off because of the stuck lens. This is one of the most common errors with any digital camera. Check the ideas from this site and see if you can resolve that. Ultimately if nothing works you may have to replace the lens since repair parts are almost impossible to obtain. Use something like these guides Kodak PixPro AZ251 to work on your camera. Once you remove the motherboard, you can see the screws that hold the lens in. If you need further help with that, post some good pictures of that you are looking at once the board is removed. That way we can see what you see. Adding images to an existing question
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
snjsjs будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 32
