The Xiaomi Redmi Note 9S is a mid-range smartphone by Xiaomi released March 2020. It has a 6.67" IPS LCD display, a 48 MP main camera, a 5020 mAh battery, and runs on a Qualcomm SM7125 Snapdragon 720G.
Why is my phone's turbo charge doesn't function anymore?
battery drains fast and overheats.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Make sure your charger and cable are still good and provide turbo charge. Also if your battery drains fast you should replace it and a bad battery also could take less power at charging, so that's why it doesn't turbo charge. Also try to clean your charging cable and port with a toothbrush with some alcohol on it. Be careful put a small amount of alcohol on your toothbrush and not directly to the port and before plug your charger on, make sure it is dried.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Merly Caril буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 13
За всё время: 266
