500 series DSLR camera developed by Nikon. Released in February, 2011.
26вопросов Показать все
Please tell me how to increase the magnification of this camera furthe
Coolpix P500's 36x magnification is not enough for me! I would like more magnification. Please tell me how to increase the magnification further!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
As far as I know unless you want to buy a camera with more magnification you cannot just add it to your camera. However you can add a lens that allows you to have a longer focal length, which means more magnification. The Nikon Coolpix P500 allows you to add different Nikon as well as third party lenses using a 67mm adapter. This video helps with attaching your adapter which is just basically a metal tube. Then you can choose for a lens and here you have a wide variety so you can really choose what is best for you. Good luck ^-^
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
So what should I buy?
из
If you look for “nikon coolpix p500 67mm adapter” you can find various ones which should look like a metal tube (some websites are out of stock). KnF https://www.kentfaith.com/feature_nikon-... should still have one however unfortunately I’m not familiar with Nikon cameras and their compatibility between different camera lines
из
Добавьте свой ответ
Lee Seyoon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 29
