The Galaxy A12 is a low-end slate Android smartphone released by Samsung in November 2020 as a successor to the Samsung Galaxy A11. Identifiable by model number SM-A125 (followed by version/carrier-specific character.
158вопросов Показать все
Incoming whatsapp calls not able to receive
Not able to receive incoming whatsapp calls
Это хороший вопрос?
Оценка 0
1 Комментарий:
Samsung A12 android mobile phone, not able to receive incoming whatsapp calls but can make whatsapp calls. The mobile is two years old only. Uninstalled whatsapp and again reinstalled whatsapp but no luck
из
Добавить комментарий
1 ответ
Have you ever had it working?
Have you registered the correct phone number and had it verified?
You might want to ask the question on the WhatsApp forum, there all users there.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Number has been registered correctly with the correct name but no incoming whatsapp calls. If this wasn't registered correctly I would not have been able to call others too from my number
из
@radhikaram30733
What message does a caller get when they try to call you on Whatsapp?
Just to eliminate things try using the phone in safe mode and check if whatsapp now works both ways.
из
Добавьте свой ответ
Radhika Ramamurthy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 29
