The Craftsman Pressure Washer 580.752501 is a gasoline-powered residential cleaning tool, capable of generating up to 2500 PSI of pressure and a flow rate of 2.3 gallons per minute. This page provides information on its features such as an 11.87 cubic inch engine, an axial cam pump, a 25-foot high-pressure hose, and 4 quick-connect spray tips, along with guidance on repair and use.
How can I buy a fuel tank
How do I buy a fuel tank
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
@robertmitc76367 the fuel tank is part of the Briggs and Stratton 126T02 engine that your Pressure Washer is using. Of course, this is only true for as long as your washer is a Craftsman 580.752501 like you selected. The part number for the Fuel tank of the Briggs and Stratton engine is 699374
Replacement fuel tanks are available at B&S as well as many other places.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Robert Mitchell будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 100
