The Galaxy A12 is a low-end slate Android smartphone released by Samsung in November 2020 as a successor to the Samsung Galaxy A11. Identifiable by model number SM-A125 (followed by version/carrier-specific character.
160вопросов Показать все
Why is my phone battery drain automatically
My phone was automatically draining. When I didn't use phone but also it's draining.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hi @jitu43737
When you are not using the phone but the phone is still turned on, turn off the following unless you need them on for some reason and check if the battery charge takes longer to dissipate.
Turn off WiFi and Bluetooth and also disable the internet connection by turning off the Data saver settings. Go to Settings → Connections → Data Usage → Data Saver.
Only turn them on when you need to use them and turn them off when you're finished.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Jitu будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 12
