Здесь вы найдете инструкции по ремонту и дополнительную информацию для морозильной камеры Gladiator GAFZ21XXRK0* — отдельно стоящей вертикальной морозильной камеры с одной дверью и системой автоматического размораживания, выпущенной в 2005 году. На этой странице представлена информация для номеров моделей, соответствующих шаблону GAFZ21XXRK0*.
It’ll run for about a minute then shut off
I plug it in and it’ll run fine . Both fans and compressor are running and in about a minute it’ll shut down like I unplugged iy
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi @kevinmcpike,
Does the light in the compartment still work when this occurs?
It seems like it may be a faulty Overload and PTC start relay - part #13 Unit parts diagram, part #WP2154697 (supplier example only) and hopefully it is not a faulty compressor.
Ideally to test this you would need an AC clamp meter to measure the compressor current draw when it is starting/running and check if it is within the specifications.
It is in within specs then it may be a faulty PTC relay. Search online for the part number to find suppliers that suit you best.
Unfortunately looking at images online of the compressor part #W10309994 there doesn't seem to be any amp load rating specifications shown on the label. Check the label anyway just in case it is on your compressor.
If you have a DMM (digital multimeter) you could do a static test i.e. no power connected to the freezer and check if the compressor windings are OK. Here's a video that may help with this.
If it is the compressor, then depending on your location, you may need to use a licensed repairer to replace it due to the environmental regulations regarding the handling of refrigerant gases
Versatile multimeter with all the right functions for basic electronics troubleshooting. Изображение
Товар
Digital Multimeter
$59.95
Includes the compressor, relay, overload, drier filter, tubing, and mounting grommets for refrigerator cooling systems. Изображение
Товар
Whirlpool Compressor Kit - W10309994
$363.99
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
kevinmcpike буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 27
За все время: 439
