Guides for the Wi-Fi version of the iPad mini 5—model A2133. Released in March 2019, the iPad mini 5 is the successor to the iPad mini 4.
Digitizer not working after replacement
I bought a replacement Screen and digitizer The screen works great but the digitizer docent some spots don't register on the left and right in portrait mode and in regular mode I can't see ANY damage The connector looks good. Is there Something you have to cover or is it apple's prioritization
Это хороший вопрос?
Оценка 0
1 Комментарий
don't have the original screen but the old digitizer worked perfectly except it was cracked and the display
из
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
You didn't mention if you had cleaned the connector with some 90% or higher isopropyl alcohol, but other than that it looks to me as though you've covered pretty much all of the diagnostic bases.
At this point I would communicate with the seller of the replacement screen on the issues you're having with it and see about getting a replacement, especially given that you didn't have digitizer issues with the original screen.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
thanks I cleaned it am waiting for it to dry. let you know if it works.
из
Добавьте свой ответ
Alistair moran будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 90
