The Apple ImageWriter II is a dot-matrix printer released by Apple in 1985. It accepts both line feed and regular 8.5 by 11 inch paper.
Apple ImageWriter II won't print from Macintosh Plus
Hello! My Apple ImageWriter, even when connected to my Macintosh Plus through the correct selected ports, will not print. After I ran the self-demonstration, it proved that there is not a mechanical failure, and it will print. Whenever I select print in a document, it says it is printing, but nothing happens. Eventually, the pop-up goes away.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
You need to open the printer selector dialog box to reset the port. It’s likely the CMOS battery needs replacing as the setting got lost.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
I have checked all settings, and they appear to be OK. I think it might the cable I was using that I bought. It might not have had the right pinout.
из
@wmf10 - this is a different cable than before?
из
Добавьте свой ответ
_nec6678 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 133
