A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
MacBook doesn't start after battery replacement
Hello,
In my MacBook A1708 I replaced battery. After that MacBook doesn't start. Nevermind if charger is plugged or unplugged.
If I unplugged flex battery connector - MacBook starts with plugged charger. Do you have some ideas what gone wrong?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
I would suspect the cable or the connectors have been damaged somehow so you have a short. Otherwise the battery maybe defective.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
I ordered a new cable, I will let you know after replacing it if it solved the problem
из
Problem resovled. After replace flex battery connector MacBook works fine
из
Добавьте свой ответ
Dariusz буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 7
За последние 30 дней: 24
За всё время: 256
