My MacBook is frozen and it will not shut down. What's wrong?
My MacBook has been frozen for two days now, and I can't turn it off. I have tried the power button as well as command, control, and power buttons simultaneously with no result. I can move the mouse, but I cannot do anything when I try to give a command. When I push the power button, the screen goes black. And when I turn it on again, it looks like it goes to sleep and wakes up on the same screen. Any suggestion?
P.S I haven't tried to take out the battery because I'm scared maybe something worse will happen.
Это хороший вопрос?
model nr----A1342
из dedej33
My kids got ahold to BOTH!! Macs! My IMac and MacPro....no telling what they pressed....please help! On the iMac the program's either take long to open or just doesn't open at all....the MacPro is froze the mouse pad works but can't click on anything or nothing will open but it's able to charge and sleep HELP!!!!
из Geneen
I can't exit my gmail.com account - nor can I shutdown my MacBook Pro
из Mary Katherine Brand
Sean McGuire, you are a legend! I've had this issue for months with no solution unti I came across your post.
My iMac had never run so good. How did you find how to do this.
Thank you, than you, thank you
Regards
Chris
из Chris Oates
My MacBook froze and didn't work nothing worked while I was using iMovie, so I held the shut down button for like, a minute and restarted it, pretty slow though, should start working
из Tracey
