I replaced the right joystick but now I can't get it to pair?
I replaced the right joystick because the controller was dropped and broke the enternals of the potentiometer. After I replaced it, everything "appears" to work normally. The controller vibrates when receiving power and the icon lights up. I put it into pairing mode but nothing is finding the signal (pc nor phone). This is my first time working on a non-playstation hardware and I do not have an Xbox.
Это хороший вопрос?
Did you try to plug it (cable) with PC and test it?
из Vertinhol
Yea, the pc doesn't even register anything being connected.
из Stephen Thomas Diggs
Double check that you've seated the boards together properly and havent damaged the connectors when disassembling it for the repair. Also, photos of the inside of the controller would help diagnostics.
из Kyle Clarito
