After a two-year hiatus, the model-year 2005 Sportage returned, sharing its Elantra-based platform with the 2005 Hyundai Tucson.
My check engine light came on code showing P0134
The check engine light came on and was only showing one code P0134. I also noticed the car has poor acceleration issues? I'm not sure if they both can have something to do with the oxygen sensor needing to be replaced? I dont know much about cars but want to fix the issue ASAP.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
First try just cleaning the maf sensor if that does not work then change or clean the oxygen sensor
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Des будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 54
