Help! My mac 'Pops' off at switch on!
My white un-web cam iMac takes four attempts to start up, making a 'pop' noise when failing, but then works well although can 'pop off' when woken from a long sleep.
Is it a bad power unit?
Please help!
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (2)
Выбранное решение
Yes, My first guess would be the power supply. Lay it down flat on its screen.. remove the back.. usually if a power supply is "popping" it will have a distinct smell.. also looks for any buldging or swollen capacitors.
Был ли этот ответ полезен?
Оценка 4
2 Комментариев:
I'm pretty sure it's the power supply because the original power supply that comes with this model is notorious for failure after long use.
из
Could be, but could also be a bad hard drive, use disk utility to verify your hard disk if that's failing, a failing drive can make popping noises.
Оценка 0
Добавьте свой ответ
Big Dan будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 2,168
