Restored, Hard drive replaced, still won't boot
A friend of mine's iBook's hard drive has been slowly dying after he partitioned it to dual boot Mac and Ubuntu. It got to the point where it would not boot unless you went through +S and fsck-fy every time and finally it stopped booting at all. At first I tried re-imaging it with a known good tiger image, this didn't work as the hard drive was in three partitions and completely broken. I then replaced the hard drive with a blank, Mac OS X formatted one. I have tried several times to image this drive via Firewire Target Mode and Disk Utility on my eMac. All of the times Disk Utility reports no problems but when I try to boot the iBook, I get that screen where the folder with the finder face flashes with a question mark. When I boot holding alt, it can detect no bootable drive.
(If it helps, I know the iBook is functional because I can boot from a CD)
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Выбранное решение
Sometimes machines which "wake up" the first time with an image or install of the OS that was actually performed on another machine have trouble recognizing the hard drive as the primary boot device. Sometimes that folder will flash for a while, and then it will eventually find it. You might try resetting the PMU and PRAM. Actually, this vaguely sounds like a scenario which may involve the machine having a PRAM/open firmware password in place (machines that do can be especially problematic), so you may want to change the amount of RAM and immediately reset the PRAM three times in order to clear a PRAM password, in case there is any possibility of the machine having one.
Unless I'm reading you wrong, it sounds like you haven't tried to do a regular OS install on this machine, i.e. put the Tiger DVD in the machine, etc. If you haven't done this because you are not able to for some reason, then that could possibly support evidence that there is a password in place, as I mentioned above.
Был ли этот ответ полезен?
Оценка 0
5 Комментариев:
How was the new drive formated and on what machine?
из
I obtained the drive from the supply at QEII, where the iBook came from. The drive is apple manufactured and disk utility says it is formatted "Mac OS X Extended" (it's not "journaled")
из
How would a password have come to be in place? This iBook was used frequently before it broke primarily for word processing.
из
A password is added via open firmware. A lot of schools do it as a security measure. The password is not needed when logging into the machine...it only becomes a problem when you want to re-image the machine, or boot from another device, etc., so it's very possible the machine has been used for years and no one ever tried to wipe it, etc. Can you boot in option mode? If it's got a password it will display the lock icon, and if it doesn't, option mode will work. That's the simple way to tell if it's got one.
из
I can hold alt (opt) at start-up to view the boot drives, but there aren't any recognised. I'm pretty certain QEII doesn't put these passwords on as I very frequently image them or enter things like alt mode or +S
из
Наиболее полезный ответ
Have you tried booting holding down the option key? Ralph
Оценка 1
2 Комментариев:
I assume you are using this method because the iBook drive won't read a dvd to install Tiger. If you can access the drive using firewire have you tried using the startup disk in system preferences to set the boot disk? Ralph
из
I have no tiger DVD. I have used firewire target mode previously with success. The option key is the alt key, there are no drives recognised to boot from
из
Добавьте свой ответ
QEII Student IT будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,844
