Hard Drive does not start up after replacing left Fan
I replaced the left fan on my MacBook Pro. While the top was open, I started everything up to make sure everything loaded correctly all the way to the login screen. It worked fine so I closed everything up and tightened all the screws. Then when I tried starting it up it got to the apple screen with an empty progress bar bellow it. I see the spinning progress wheel but nothing else happens. Please Help.
- More information ****
Tried resetting the NVRAM. Reopened the computer and all connections are secure. The problem persists. I was able to get the laptop to boot off of an external hard drive (which already has a boot patrician) When I open disk utility, the "MacBook Pro" Volume (which is my internal hard drive) does not mount. Verifying the disk tells me that the disk needs to be repaired.
Это хороший вопрос?
1 Комментарий
It could be a coincidence but your hard drive may be bad. Install a working one or try to repair the faulty one with DiskWarrior.
из lemerise
