My 1998 honda acccord sedan gearshift handle won't come out of park
my 1998 honda accord sedan gearshift handle will not move out of the park position
Это хороший вопрос?
Это хороший вопрос?
Jay,
There should be a plastic cover on the console near the shifter. Sticking a screw driver in and removing that cover will reveal the brake interlock. Depress that and it should come out of park.
Alternatively, it may be a bad brake switch. Regardless, the first method should get you out of park.
Good luck,
Frank
Был ли этот ответ полезен?
Have someone check the 3 brake lights when you press on the brake pedal, if any of them is/are out, check the fuse for the brake lights and replaced if blown. I had a blown fuse and have to use a key to shift to Drive untill I changed the blown fuse.
Good Luck,
Murphy
I .checked all the fuses and they are good. I can shift it by putting a screwdriver in hole and unlocking shifter,but need to find reason it won't work right
@Ramon Mejia
What is the year and model of the vehicle?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,953
