iPod won't turn on or off?
My iPod's screen is frozen. It won't turn on/off or anything what could be the problem/solution?
Это хороший вопрос?
Это хороший вопрос?
Press and hold the middle button and the menu button at the same time. This should perform a hard reset and unfreeze the device.
Был ли этот ответ полезен?
My iPod has had similar issues in the past, in which even a hard reset would not work. If that is your case, just let it drain itself dead and then charge it back up. You should be good to go then!
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,239
1 Комментарий
Is the little switch on the top in the "Lock" possition?
из Chris Green
