To start troubleshooting water damage, it needs to be cleaned off to avoid further damage to work with and do more harm
Take the computer apart and remove the heatsink, soak the board in isapropal alcohol for a hour or 2(you should clean your heatsink and fan too while it's apart too), and scrub it gently with a toothbrush to loosen dirt, let it dry for a few hours and put the heatsink on and use quality thermal paste and work from there
If that does help, it was just dirty
This is all we can do right now till this is more clear on what it is doing after the boards is clean
Here is a page on dealing with liquid damage
Electronics Water Damage
Here is the guide to take the computer apart
MacBook Pro 13" Unibody Late 2011 Logic Board Replacement
As per my suggestions for thermal paste, don't bother the cheap stuff all OEM's use, it's that bad. I suggest Artic Silver 5 hands or Cooler Master High Performance thermal paste instead of the cheap stuff Apple uses from the factory all over again
The thermal pastes I suggest
http://www.amazon.com/Arctic-Silver-Poly...
http://www.amazon.com/Cooler-Master-Perf...
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
6
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
2 Комментариев
Bob (with iFixit), when you change the question, and delete part of it, it makes the answer confusing.
из mayer
I think I have this translated. he is saying since he split water on the laptop, it doesn't turn on over battery, but the computer does with the plug, and it boots to a black screen
из Nick
