New Battery Installed, Health is good, But it won't charge.
Bought a new Battery for my laptop, turned it on and plugged in my power adapter. The light did not turn on, and it's not registering as plugged in. Battery health is good. (Photo attached)
Prior battery required servicing, but is now not charging either.
I've tried all the resetting tips so far. Including unplugging the battery and just using power from the adapter.
I've got another charger being delivered tonight.
However, if it is not the battery, or the charger then what is it?
I/O board? Data cable? Magsafe port?
Update:
The MagSafe port on the logic board was cracked which meant it wasn't connected properly. I've now superglued the cable in and it is charging fine. Thanks for the help, sorry for the bother, I should have given it a once over previously.
Это хороший вопрос?
1 Комментарий
@danieljone77026 - if you’re set don’t forget to accept the answer - Thanks!
из Dan
