Fix your 5G Edition Samsung Galaxy S10 smartphone with these replacement part DIY repair guides.
My phone fastly overheats (like 3 to 5 minutes it's normal then lags)
can anyone please help me I'm currently using my old phone and it's pain in the butt it's such a downgrade it's so hard to used. I used my Samsung for my everyday life this happened before and it happened again!
Это хороший вопрос?
Оценка 0
1 Комментарий
@apl42780do you feel any heat? Does it get hot on the back, front, top bottom?
из
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Hi Apl,
Due to the nature of batteries and chargers, three outcomes are possible here:
  1. The simplest one - a process (or multiple) is overusing your phone's resources and your battery.
  2. Faulty charger or charging port - A charger and a charging port can generate heat due to compatibility issues. I would advise trying a new charger here or (as a last resort) attempting to replace the charging port.
  3. This one is unlikely, but can still happen - A faulty battery. Batteries can inflate and wear down over time, especially if it was used a lot back in their heyday. If none of these work, I would advise you to try to replace the battery
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
@arandomhitman if you do not add any instructions on the how-to you sound like a ChatBot answer :-) How to replace the charging port? How to replace the battery? Look at it this way. Let's make iFixit Answers a One-Stop-Shop. WE try and determine what to check, how to check and how to replace it. That way any OP will get their question completely answered.
из
Добавьте свой ответ
Apl будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 110
