Released 2004, identified by model number LS743.
Is there another way to charge the camera?
I've recently recieved this camera, It didn't come with any charging cables so I looked to find one, only to find out that apparently you're supposed to charge the battery externally?
Is this true? Can't I just charge the battery with an AC plug or USB?
Thank you for your guides.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
@rustern that is correct. This camera will not charge the battery. For that you will need to get an external battery charger. Do not do anything with AC on this camera since that would have catastrophic results.
Replacement chargers are readily available at many places like this
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Rustern будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 5
За последние 30 дней: 19
За всё время: 112
