HP Laptop 15-dy1xxx peripherique d'amorçage introuvable
Google translate:
boot device not found
Это хороший вопрос?
Google translate:
Это хороший вопрос?
If this happened suddenly, your hard drive is most likely dead. Go into the BIOS to check if it is detected there. If not, replace it and re-install windows and you'll be up and running again!
Был ли этот ответ полезен?
@sawadogoahma470 totally agree with @stuig on this. It does look like a drive may have failed. To enter the BIOS turn on or restart the computer and quickly press F10. Now follow the screen menu to determine which drive is your bootdrive and if the BIOS can "see" it. It looks like your computer does not use a HDD but uses an SSD as the primary drive.
If it can't, it is most likely a failed drive. Here is the HP Laptop 15 Dy1xxx Maintenance And Service Guide and page 71 will tell you about the BIOS. Page 33 will show you how to replace the SSD. Identifying, Preventing, Diagnosing And Recovering From Drive Failures should help with the diagnostics as well as a recovery of your SSD.
While you work on your laptop, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@sawadogoahma470 tout à fait d'accord avec @stuig sur ce point. Il semble bien qu'un disque soit tombé en panne. Pour entrer dans le BIOS, allume ou redémarre l'ordinateur et appuie rapidement sur F10. Maintenant, suis le menu de l'écran pour déterminer quel est ton disque de démarrage et si le BIOS peut le « voir ». Il semble que ton ordinateur n'utilise pas de disque dur mais un disque SSD comme disque principal.
Si ce n'est pas le cas, il s'agit probablement d'un disque défectueux. Voici le Guide HP Laptop 15 Dy1xxx Maintenance And Service Guideet la page 71 t'informera sur le BIOS. La page 33 te montrera comment remplacer le disque SSD. Identifying, Preventing, Diagnosing And Recovering From Drive Failures devrait t'aider à diagnostiquer et à récupérer ton disque SSD.
Pendant que tu travailles sur ton ordinateur portable, prends beaucoup de photos. Une fois que tu as terminé, prends ces photos et crée un guide pour iFixit. Cela aidera la prochaine personne qui aura un appareil avec les mêmes problèmes que toi. C'est facile et amusant de créer ces guides. https://ifixit.com/Guide/new La communauté iFixit appréciera.
La réparation est la guerre contre l'entropie !
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 56
