Repair and service information for the Ryobi 3300PSI 2.3 GPM Cold Water Gas Pressure Washer with Honda GCV190 Idle Down. Model Number: PSI RY8094
Where can I buy the uploader valve
where can i buy the uploader valve
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
@wilmeister37410 if you are referring to the unloader valve by the pump, that is part number 310924003
It is widely available since it has been used in many different pressure washers. Available from Amazon to Walmart.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
this is what the cs told me after 5 hours on hold talking to 4 people. he 1st tried to say that i had to buy the whole pump. but ended up verifying the number
из
the whole problem is they do not have the uploader valve on the parts diagram therefore there is no part number to verify t
he correct fitting of the unloader valves i found
из
Добавьте свой ответ
WiLmeister буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 10
За всё время: 197
