Hey hi Stephanie, I really hope your having a wonderful day✨ Let's see where are you stuck at, look's like your Samsung Galaxy S21 5G had a faulty screen, you replaced it and now the touch is not working. Don't worry, we can get it fixed😄
The following tip's will help you get you phone fixed up👇
- Try to inspect your new screen
# As you mentioned that you have ordered the phone from this link, I went to the site and saw that it does not have any good reviews. It rating is also low, I would recommend to return and buy a screen from somewhere else.
- Check the connectors
# You might want to check the connectors twice . Make sure they are in place, connected, not ripped apart or damaged, and correctly placed.
- Restart your phone
# Sometimes, after a hardware upgrade or anything. All your phone needs is a restart to set up the new screen. Give your phone a restart and check if it works.
- Update the phone
# Try updating the phone if there are any. Sometimes it does help and get the phone fixed
- Try another screen
# Try the broken screen (because it still works, all it does it that it has lines or the display is not good) and see if works. If it does then the problem is 100% with the one you have right now. Return the screen and find a trust worthy place on the internet to buy a new screen for your Samsung Galaxy S21 5G 🎗️like the one I found on IFIXIT itself, here is the link to it🎗️. Sure it is cheaper and better with more assurance.
That is all I can recommend buddy, try these steps and see if it works. If you have any more doubts, queries or got stuck somewhere. We are always there to help you out😄 Do try to reach out to us whenever needed. Thank you for reading and I appreciate to those who did. I really hope you loved the answer and have a 🌟Gorgeous day🌟
Был ли этот ответ полезен?
Проголосовали
Отменить
Счет
Отмена
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
