My fingerprint sensor just stopped working, nothing happened previousl
Nothing happened to the phone,it didn't drop,cos I use it for my bank app, I did a transfer and used the fingerprint then I wanted to do a transfer after getting a haircut, it hasn't worked since then
Это хороший вопрос?
Счет 17
8 Комментариев
My tombprint is not working
из
@kabiruhussaini same as my original answer
из
thanks you fingerprints in active
из
My fingerprint settings have disappeared, and the sensor is also not working.
из
из
Показать ещё 3 комментариев
Добавить комментарий
3 Ответов
Наиболее полезный ответ
@afhorafolabi first try to reboot your phone to check if your fingerprint sensor is working. IF that does not work you want to check and update your software. Go to Settings==>About Phone==>System Update and let your phone check for any updates. If there are any, those should show up as Download Update. Use those to download and update your Tecno-Spark-8-Pro
You can still clear your cache and other things if the above did not work. Check sites like this one for how to clear your caches etc.
If your fingerprint sensor hardware does not even show up in your settings etc. then it is possible that this is a Tecno firmware issue. You'd have to check with Tecno support or their individual forum for that.
If none of that worked, you may have an actual hardware issue, like a failed fingerprint sensor. Since iFixit does not yet have a guide for that, try something like this video It is not specific to the fingerprint sensor but will at least get you into your phone.
Replacement sensors are readily available at many online stores. Purchase one from a vendor to your liking, just make sure you purchase a fingerprint sensor for your exact model.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
Hot and screen touch slow to respond sometimes.
из
in service center guys said to me: "uhm, we don't know what the hell is this, we changed the sensor, 3 times wiped data and re-flashed, checked all what can be broken...", lol
из
Well I will suggest you to update your banking app to its latest version and also check for the software update of your phone to it's latest version.
Счет 0
Fingerprint hardware not Available
Счет 0
Добавьте свой ответ
Afhor Afolabi буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 30
За последние 30 дней: 158
За всё время: 3,003
